Topic: bucking? (Read 1758 times) previous topic - next topic
bucking?
my car is bucking when accelerating over 20-30mphs I have no clue what it is? and its getting real annoying hope someone can help me
bucking?
pull the codes yet with a paperclip and a test light or buzzer?
first thoughts .........bad,,,,,,
wires or tune up parts
TPS worn
fuel pump presure too low or not constant
dirty trottle body
clogged pvc system
TFI
Pick up module
ect ect
bucking?
Yes, first step is to scan the car for codes.
If you are unable to do it or have no clue how, AutoZone can scan it for free.
bucking?
i thought u can only scan for codes if the check engine light was on?? and if it is the motor wouldnt the rpms go down when it bucks? cause they dont i dont know if theres a delay with the dig dash or what
bucking?
When you say bucking, does it feel like the car wants to downshift but doesnt?  Kinda like is it stuck choosing what gear it wants to be in?  If so, my old Thunderbird had the same problem.  I think we fixed it by changing an o2 sensor, but I may be wrong.  It's been a long time since I've had that bird.
bucking?
no its not when shifting its when giving it gas
bucking?
Your check engine light does not have to be on. There could be error codes floating around that won't trip the light.
So far for my car, the only time my light has come on was when I had a cut in a vaccum hose.
bucking?
here ya go,,,,,,,,,
http://therangerstation.com/tech_library/OBD_I.html
dont loose this link
your gonna have to do some leg work to figure this one out,, but bucking under a load isnt all that uncommon and when it happens,, there is an actual problem so dont ignore it or the gas tank will only empy faster.
bucking?
I just had a friend (Jason, don't remember his screen name because he has not been on due to his computer having problems) that had a bucking problem at low speed. He replaced the distributor and tfi which had solved the problem. This was in a turbo coupe that had been coverted to 5.0 with a 5 speed. I can't say that this is your problem but just trying to help.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
bucking?
You could always drop the exhust and take aquick run down the street just to test if you have some sort of exhust blockage. My Turbo coupe did this when the CAt was plugged. It would start and idle fine but as soon as you gave it gas it would cut out and not wrap up.
