Topic: 5.0 Heads Swap (Read 1087 times) previous topic - next topic
5.0 Heads Swap
Need a liitle help.
I may be getting a 5.0 out of a 89 Crown to put in my mustang.
I have all the pieces from a 89 H.O. and just wondering if there is enough difference or worth the time to put the heads and intake from the H.O. on the Crown Vic motor. Any advice would be great.
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
5.0 Heads Swap
yeah, you'll want to use the HO stuff on the CV engine...but you'll only be able to use a few different cams, unless you have the CV pistons fly-cut...
If you can get a set of HO pistons on the cheap..that'd be a good way to go, too...
5.0 Heads Swap
I have pistons from H.O. motor also.
Carroll IA
nwenck@msn.com
5.0 Heads Swap
everything should swap out fine. The bottem end minus pistons is identical.
