Topic: Free MN12 Cougar XR7 (Read 1013 times) previous topic - next topic
1995 Mercury Cougar XR 7 with optional 4.6L V8 SOHC 205 hp @ 4500 rpm; 265 lb-ft torque @ 3200 rpm. Cold A/C, remote door locks, ABS, Traction control, new tires. No rust on chassis, Great body(some dings). Everything works, drives great.
Here are the catches - No title, transmission needs new bands ( currently works no problem), Airbags don't work even tho they are there, Engine front seal leaks oil(minor). Brakes need new pads. No radio(stolen), dash has some cracks due to thieves, Open diff ( can't drift ), needs alignment (hit deer)(minor tire wear).
Since there is no title, this will be given away as a parts car. You can drive it home but I won't be responsible. It currently has NY plates
The car is located in Northbrook, Il. This is not my car I am posting it for a friend if you are interested PM me and I will give you his contact info. The ad is posted the way I recived the info from him.
Still working on that. He sent me the info right before he left work I won't have anything till monday morning. Also trying to ge tthe vin # from him.
slamedcat,
PM sent.
Fordman3
