Topic: Weight Loss Regime (Read 10664 times) previous topic - next topic
Weight Loss Regime
I'm putting my 88 Bird on a diet. I want it light as possible while still maintaining some comfort. From looking at the door tag my GVWR is 4448 lbs. I read somewhere that if you multiply 180lbs X (Max number of Passengers[5]) and then substract that from the GVWR you get an approximate weight of your vehicle. Now how much truth is in that I do not know, but it is my starting point of 3550 lbs. Also as I pulled parts off I weight them with a mere bathroom scale so these are just estimates.
Ok I'm restarting this program on my 87 TC (4350 GVWR/3450lbs approximate starting weight). I'll re-weigh the same parts if available and post those results in blue. Hopefully I'll be able to reproduce the 200lbs weight loss that I performed on the 88 TC.
Parts Removed
A/C System ~ 48lbs/34lbs
Fog Light Brackets ~ 5lbs/5lbs?
Rear End Dogbone ~ 10lbs/9lbs
Transmission Damper ~ 5lbs/5lbs
Trans Xmember Damper ~ ???*/4lbs
Rear Speakers ~ 1lbs
Door Speakers ~ ???*
Dash Speakers ~ under 1 lbs.
Stock Radio Deck ~ ???*
ABS Comp ~ 1lbs
PRC Comp ~ 1 lbs
Metal Bracket for Above Comps and All wiring ~ 15 lbs
Spare Tire ~ 31 lbs/31lbs
Mini Lug Wrench ~ 1 lbs/1lbs
Sound Deadening ~ 65 lbs/3lbs
Air Cleaner Assembly ~ 5 lbs/5lbs?
Center Console ~ 5 lbs
Power to Manual Seat ~ ???/16lbs
Vacuum Brake Conversion - 11lbs
Foot to Hand E-Brake ~ ???
3G Conversion ~ +2lbs
Plus One Size Wheel/Tire ~ ???
Hood Hinge w/Spring to HH w/Prop Rod conversion ~ 4lbs
Charcoal Canister ~ 2lbs
TC Dual Fans to Taurus Fan ~ 5lbs
Total Known Weight Loss: 203lbs/124lbs
Approx. Vehicle Weight: 3347 lbs/3326lbs
Any of the ??? with an (*) I don't know nor have the part anymore. If you know the approx. weight please fell free to let me know. Thanks.
Ideas of weight loss
Mini Starter (Ranger or Mustang)
Lighter Carpet
Smaller Battery (and relocate to trunk)
Aluminum Water Pump
Aluminum Radiator
Aluminum Driveshaft
Fiberglass Hood
Tubular K-Member
Tubular A-Arms (coilover conversion)
Single Exhaust (Log header, ler Delete, Exhaust Inserts)
This section I will use to keep up with various weights of different parts
TC Stock Electric Fan ~ 12lbs
 Taurus Fan ~ 7lbs
TC Hood w/Ducting for Intercooler ~ 49lbs
Weight Loss Regime
You can lose a lot of weight in sound deadening. And if you get some of the aftermarket carpeting, it has a lighter pile. It looks good because its fresh, but its not as plush, and weighs less.
Weight Loss Regime
Remove your carpet, get some dry ice and a hammer, freeze those squares of sound deadening all over the floor/sides of the car and whack them with a hammer. Theres a fair bit of weight there aswell, my guess is 20-25 pounds.
Weight Loss Regime
The total combined weight of all the A/C components is 48LBS.  Spare tire is about 10.
Weight Loss Regime
dry ice.... NOW i learn about that trick.  which car are you refering to for weight? 88 or 85?  well if you havent all the smog equipment is another thing to remove... if u do not need heater u could take that out lol
Weight Loss Regime
you could always pull the bumpers off of drill holes in them.
Weight Loss Regime
Quote from: the_intimidator03
The 88. And since I live I Michigan at the moment I may need that precious heat. :D
Weight Loss Regime
The snowflakes weigh 23.2 Lbs each, less tire, with center. The airbox is about 5 Lbs with bracket. Power seat tracks are a little over 35 Lbs each, I have some manual driver's side laying around I can weigh.
Weight Loss Regime
Quote from: Haystack
Heh, heh. Speed holes! Heh.
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Weight Loss Regime
ah ok i didnt know where you lived... my theory is... if its cold bundle up if its too hot... shed n roll the ed window down lol.
Weight Loss Regime
Quote from: Aerobird Motorsports
Hey if you know the weight of snowflakes w/tires that would be great. I'm pretty sure I gained some weight in that category. :D
Thanks for the other info too.
Weight Loss Regime
a t5 weighs alot less than an AOD too, aluminum cylinder heads are a weight saver also.
Weight Loss Regime
Just pulled the abs unit and it was 21 lbs. Anybody know the weight of the vacuum booster and master cylinder (aluminum)? Also switched over to the 3G and it is 2lbs heavier, more with all the heavy wiring I will need.
Weight Loss Regime
Did you count the factory regulator in the alt weight. it is part of the 3g. Also what about the wiring for the old style alernator. Have you got power windows or manual? if they are power get some doors with the manual windows.
Weight Loss Regime
In 88, the 2.3t came with an internal voltage regulator. The wiring is quite similar to the 3G, the plugs are the same, but the wires play musical chairs a bit. So the only other weight gain is were the heavier gauge wiring is needed... and I haven't gotten to that point yet. But I will include it. :)
I have power windows and honestly would rather keep them. LOL, I hated reaching across the car to roll up that window in my Stang. Actually, to be honest, I've never seen a TBird with manual windows.
