Topic: Weight Loss Regime (Read 1770 times) previous topic - next topic
Weight Loss Regime
I'm putting my Bird on a diet. I want it light as possible while still maintaining some comfort. From looking at the door tag my GVWR is 4448 lbs. I read somewhere that if you multiply 180lbs X (Max number of Passengers[5]) and then substract that from the GVWR you get an approximate weight of your vehicle. Now how much truth is in that I do not know, but it is my starting point of 3550 lbs. Also as I pulled parts off I weight them with a mere bathroom scale so these are just estimates.
Parts Removed
A/C Condensor ~ ???*
A/C Compressor and Hoses ~ ???*
A/C Evap ~ 5lbs
Fog Light Brackets ~ 5lbs
Rear End Dogbone ~ 10lbs
Rear Speakers ~ 1lbs
Door Speakers ~ ???*
Dash Speakers ~ ???
Stock Radio Deck ~ ???*
ABS Comp ~ 1lbs
PRC Comp ~ 1lbs
Metal Bracket for Above Comps and All wiring ~ 15lbs
Spare Tire ~ ???
Mini Lug Wrench ~ 1lbs
Trunk Sound Deadening ~ 5lbs
Air Cleaner Assembly ~ ???*
Center Console ~ ???
Power to Manual Seat ~ ???
Foot to Hand E-Brake ~ ???
Total Known Weight Loss: 44lbs
Approx. Vehicle Weight: 3504
Any of the ??? with an (*) I don't know nor have the part anymore. If you know the approx. weight please fell free to let me know. Thanks.
