Topic: 17x9? (Read 2186 times) previous topic - next topic
17x9?
I was looking at a set of rims that are 17 x 9? Will they fit without any issues? Rubbing or anything like that?
Thanks.
17x9?
more specifically these
17X9 4-108 18S
17x9?
i guess i copied the wrong picture, its a 4 lug version - hence the 4 x 108 pattern.
17x9?
i didn't read that... it was late. =/
Anyhoos, if you read through those threads then you could come to the logical conclusion that 17x9s will fit. IMO rubbing will depend on two main areas, ride height and tire size.  245s seem to be a happy medium and obviously if you plan on keeping stock ride height you should be okay.
17x9?
What he said :stupid:
If they're the same back spacing as the cobras for 4 lug mustangs then yes they will fit with out any rubbing. even with 245-45-17x9s in front I have no tire rubb EVER. But at full lock, somtimes the inner wheel hits the tie rod or the sway bar ends (i just drew a blank). But thats because I went to the fox mustang lower control arms. With stock lca's you wont have any rubbing. But the wheel will stick out from the fender.
17x9?
Quote from: bduly
They may fit ;)
Willpower is no match for Horsepower.
17x9?
are those the same backspacing and everything as the real 03 cobras and how much cheaper if any are the? do they come in chome? and were are they from, i have been thinking of puttin them on my 86 for a while now i just cant afford them
17x9?
I wouldn't mind a set of those in black......
17x9?
black with chrome lip! hey no that is the way to go but  there is so little of a lip it might not look right. dont know that is what i havee want for a while now but not sure what it would lokk like. can some one photochop that?
