Topic: noise while braking (Read 1187 times) previous topic - next topic
noise while braking
I've got an 86 cougar and i've got this annoying grinding whenever i brake.  i've taken it to 3 different shops and looked at it all myself, the rotor and brakes are in perfect condition.  i don't know what the problem is.  the grinding is in the front brakes.  anyone have an idea?
noise while braking
check you ball joints. i had one that when i would brake or turn corners it would grind on the rotor. made a real mess of things. good luck.
jeremy
