Topic: Mustang to cougar 8.8 swap? (Read 1555 times) previous topic - next topic
Wanting to change the 1987 cougar rearend out to a mustang 8.8 with 3.73 gears. Is this a straight bolt in swap with shorter axles?  What are the known issues with this swap.  What year mustang if it is year specific?  Thanks in advance
I am using the search don't kill me
I am using the search feature now.  If anyone has a quick link I would still appreciate it.
Str8 swap w/ shorter axles... AFAIK, all you need to do is transfer your brake lines over.
Quote from: bigdaddy62
i have a 8.8 out or a mustang.. it bolts right in and use the same axle that came out of the mustang rear.. only question i have is do you have 9" or 10" rear brakes? if you have 10" stock then keep them over the mustang 9" brakes..
any other questions?
Nick
I ran with the 9" 'Stang brakes when I did mine...I didn't feel like changing the backing plates and all, no problems with it.
This would be a straight swap !!!! all parts for running gear are inerchangeable with mustang cougar tbird and mark 5
Problem here lies in the fact that the track on the stang rear is 3/4" shorter on each side.
Dosen't sound like much but i seen a guy that did it and man did it look silly.
If i remember correctly though there is a way to use longer axles,read a thread about it somewhere.
The 85.5 and earlier t-birds and cougs had the same rear width as the Mustang, but 87, yes, would definitely be wider.
