Topic: 351W C6 Swap (Read 5694 times) previous topic - next topic
351W C6 Swap
I have a 1987 T-Bird that currently has the V6 and auto trans.  I have a 351W and C-6 tranny to drop in.  How much problem will I have with this?  I will need the 351 double hump pan.  Will the k member work?  Will the stock type motor mounts work?  I heard it was hard to get a C-6 into the car because the floor pans will need to be bent.  How much trouble is it really?  Will the double hump cross member work with the C-6?  Thanks for any help..First time here.
Re: 351W C6 Swap
The C6 will fit fine, I have one in my LS right now. The mounts should work, yes you will need the 351 double sump pan, you will also need 351 specific headers. (for a Mustang).  I had that combo in my old 86 Cougar, there are a couple people on here with 351W. Good luck, it's a fun combo!!! :ies:  :ies:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: 351W C6 Swap
Thanks for the help.
Re: 351W C6 Swap
You're welcome!! :ies:
Re: 351W C6 Swap
Would the tranny mount line up with the stock crossmember or will one need to be fabbed?
Re: 351W C6 Swap
All I can say is it lined up on mine. :grinno:
Re: 351W C6 Swap
it will line up just fine, unless you have a QA1 k-member or the like, i think they move everything back like a 1/4" or something...not sure, just what I've read in a car mag...so don't quote me on this..lol
Re: 351W C6 Swap
As for getting the 351W in there that is easy.
U can get the C6 in there but that trany takes alot more HP then other ford tranys,  The C4 would be much better or built AOD and u get the OD as well.
I have 351 with a T5 in my car right now and i will be switchng to A833 tranny soon
Re: 351W C6 Swap
Really?! What bell housing does it take to get the t5 to mount to the 351; which is a Windsor I assume.
Re: 351W C6 Swap
Quote from: N8R
Well 351W and 302 use the same bell housing.
the flywheel u will need to get 351 that has right waight.
its ether 28oz on 302 and 50oz on 351W or its the other way around.
The pliot bearing is the same 302 on that fits into 351 crank.
thats about it
Re: 351W C6 Swap
If I recall, 289/302/351W and even a few other engines like the 250 I6 share the same bellhousing bolt pattern. (I think also the RWD 3.8 V6, but it's REALLY late and my brain's dead for the night)
Re: 351W C6 Swap
i;m dead tired and hurt,  I was helping a buddy get his car out of snow at the shop and put plywood down to push the car onto so it could roll.  He some how did not under stand the idea of going slow and guned it.  The ply wook shot out the back and got me in just above the ankle and sent me flying.  Dam lucky i dont have my leg broke right now.
On side note his car still stuck
PS i have pics LOL
Re: 351W C6 Swap
dayum, it's a  wonder it didnt take your leg clean off...be like a 50 pound or more frisbee, more or less...I'd have at least cussed him a blue streak...lol
Re: 351W C6 Swap
well its kinda ok now. I think i have a pemament dent in my leg LOL
