Topic: fuel problem (Read 3669 times) previous topic - next topic
fuel problem
ok everyone Im not sure this goes here so if not someone please move it to the right place.  My dad has a 86 mercury sable and the fuel pump isnt pumping fuel. They replaced the pump but no go it still isnt pumping. My first thought is its something electrical causing it like a relay or something. They said the car was just going down the road and it was like someone turned the key off and then back on. They did get the fuel pump to kick on once since they replaced it but only for a second and not long enough to build any pressure what so ever. Ive never had a problem like this in my bird other then when the little rubber line inside the fuel tank rotted out recently. That has been replaced when the new pump was put in. Being an 86 I wouldnt think the fuel system would be any different then our cars other then maybe the length of the wires. Any ideas on it? Im thinking its not getting power to the pump. Also if this sounds like a relay problem any chance anyone knows where its at in these cars?
SOLD!!!!
fuel problem
sounds like a relay
fuel problem
yeah update on this problem autozone says theres no relay for the fuel pump in the car what so ever Im thinking theyre smoking to much of the kansas ditch weed or something shouldnt all fuel injected cars have a fuel pump relay?
SOLD!!!!
fuel problem
yeah, otherwise it wouldnt turn on. Check the kill switch on the passenger side of the trunk. You know, the gas cut off. It is more then likely the culprit.
fuel problem
you mean the safety switch if you get in an accident? thats been reset
SOLD!!!!
fuel problem
Look under the hood, somewhere, see if there's a fuse box with the big fuses, one went bad on my truck once, wouldn't let it get fuel...
fuel problem
well according to the guy whos working on it they checked all the fuses but they dont know where the relay is to check it
SOLD!!!!
fuel problem
well, then, I'd say check the fuel pump electrical connector, and test it with a test light, or volt meter, and then check the wiring back to the eec...i know it's pita, but something's not sending juice somewhere...
Might try looking up a wiring diagram, as well.
keep us posted
fuel problem
thats pretty much what I told them. They have some kind of idea about just hooking the fuel pump up directly to the ignition switch which I think is kind of stupid but its not my car so if they break it then its on them.
SOLD!!!!
fuel problem
*cough* a haynes manual may come in handy.
http://www.automotivehelper.com/cat337/  < sable forum
fuel problem
The box you see when you take off the plastic shield, the one mounted
directly under the plastic shield, is the module. In it is housed the fuel
pump relay, eec relay, cooling fan high and low relays.
fuel problem
ok that would be like having the instructions and actually I think they have that and they said it doesnt really help them locate it dad also mentioned something about changing a box under the hood with a bunch of fuses and stuff in it would that be the sheild your talking about?
SOLD!!!!
fuel problem
Quote from: SLEEPER T-BIRD 87
forgot to add it is the shield on or near the raditator.
fuel problem
yeah that might be the thing he was saying the replaced I'll have to check when I go down this weekend if I make it down there
SOLD!!!!
fuel problem
any luck?
