Topic: Rear sway bar size (Read 2180 times) previous topic - next topic
Rear sway bar size
Well I was playing with the Tbird this past weekend and I noticed something about my stock rear sway bar. If I punch the throttle in a turn the rear of the car will start to come out a very little bit before it goes back to understear. Now I have the stock V8 LX rear sway bar (ie the really little one) so if I upgraded to the 7/8" TC one would that help to induce some controllable overstear? I'm just looking to balance out the handling a little bit. Oh yeah the front sway bar is the 1 and 1/8" sway bar with poly bushings and endlinks.
Rear sway bar size
You could try it, but I doubt it would do much. The rear swaybar design on the Fox-platform cars sucks.
Also, turbo coupes didn't have a 7/8" rear swaybar...it was more like 3/4". I got a '99 GT rear swaybar on my car and it is in fact 7/8".
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Rear sway bar size
Oh well I'll give it a shot and see what happens. Now I just have to find a '99 and up GT.
Rear sway bar size
I was told '96-98 Cobras had a 1" rear bar...but you will pay some bucks to get one of those (last I heard it was around $150).
It's too bad nobody's selling new take-off '99-04 Mustang parts on ebay anymore because thats where I got my '99 GT rear bar. Originally found it on ebay as a new takeoff and got it for something like $35? I've had the thing for over 5 years though, originally ran it on my Mustang and now it's on my TC.
Garrett H.
Exhaust sound clip
Another clip
Rear sway bar size
96-98 GT's had a 24mm solid bar
The Cobras used 26mm and 27mm hollow bars which were replaced by a 25mm solid bar because they kept breaking the ends off.
It may help a bit, but....and I know you're tired of hearing me say it...your wheels/tires are probably more the issue.  Even getting some CC plates up front to allow for more positive caster will help with understeer a bit and allow for more front grip.
Rear sway bar size
That is a good point. I do plan on upgrading the wheels/tires in addition to the rear sway bar. Those 215/70/R14 tires just don't cut it any more. I'm more than likely going to go with 17"x8.5" '93 Cobra replica wheels. Any idea on a good size tire for a wheel that size?
Rear sway bar size
Nothing wider than a 245-255 in a 45 series tire... 275/40's MAYBE in the rear on an 8.5" wheel.
Rear sway bar size
I was thinking a 245/45/R17 tires would be a good fit. I don't want big tires in the rear I'd rather have them all the same size. I don't want it to look like a red neck car:hick:
Rear sway bar size
I'm starting to think that my tires are too big and cause more problems than they solve.  I have 245/50/16 tires on stock snowflake wheels.  This is about the widest tire you can fit on this wheel and I think that's a bad thing, but I wasn't quite as wise at the time.  Snowflakes are 7" wide to my knowledge.  Is this a problem?  Does this cause the sidewall to be very unstable?  They look great, but I really don't care about looks as much as stability.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
Rear sway bar size
Quote from: jlewis05
http://www.miracerros.com/mustang/sway2.htm
This appears to be accurate for future reference.
lol, i was just about to post that. it's a nice site. got tons of info. :)
