Topic: Battery relocation, 3g alt wiring (Read 1167 times) previous topic - next topic
Wondering if anyone has moved their battery to the back here and how they did it.  Kinda worried that if I just run the wiring under the car that it will grind the insulation off and start a fire or anything like that bad.  Anyone ever ran the wiring inside the car?  What kind of wire did you use...looking into using 1/0 weld wire.
Also, if you did do this, how did you end up wiring the starter solenoid, altenator?
Thanks,
aaron
http://www.coolcats.net/stockmod/modified/battery.html
Have you looked here? That might answer your questions
SOLD!!!!
