Topic: gasguage (Read 1662 times) previous topic - next topic
gasguage
I have a problem with my 88'cougar's gas guage.It's jumps around and then it will read normal(???).But as i drive it will fall below E.
But will park it and get back in to drive it goes back to the correct
amount.I think;what's the deal...
gasguage
bad float in the tank ?  someone who really knows will tell you but thats my first thought
Z
EDIT: or the whole sending unit
hunting for another 87-88 bird
If it's got tits or tires its gunna cost you money !
gasguage
loose/dirty connection on the tank
gasguage
Hey guys thanks;but were would that be on the tank.And is it easy to get to?
gasguage
I believe its on the top front of the tank, newest bird i've bneen under is 86. Crawl under and have a peek
gasguage
will do...love this site lots of help!
gasguage
My car does the same thing, but its because I tried to "fix" it when I changed my fuel pump.  Went from a small dead spot to a  big one.
gasguage
so what you're saying is leave it alone;and just get it fix correctly,
and save myself a headache...sounds smart to me.
gasguage
I had a similar problem with my car...but the temp gauge would mimic it exactly...mine was a poor ground on the cluster regulator...went away when I took it apart and did the speedo mod.  Good luck with it.
gasguage
I'll look into it,i'm off until monday so i'll have alot of garage time.
