Topic: AOD Gear selector level offset (Read 2248 times) previous topic - next topic
Just put in a new AOD transmission, and found the column shift linkage does not line up good with the gear select lever on tranny.  I compared it with the old tranny & discovered the selector is shifted by about 45 degrees - the linkage won't adjust this much, I'd need a longer linkage arm.  Anyone ever seen this & have ideas about what to do?
V6->V8HO 88 LS
5.0L V8 87 XR7
