Topic: TV repair help? (Read 1302 times) previous topic - next topic
TV repair help?
Ive got a Sony 32" TV that i can have if i fix it.
The problem has been gradual. When it was new, you turn the TV on, and it would buzz, take 2 seconds, then the picture and sound would come on. After having it for a few years, it would gradually take longer and longer for the picture to come on, but the sound always came on in its normal time. Well, the picture stopped coming on.
The TV is disgustingly filthy, so im going to open it up, and blow i all out, which probably wont fix the issue, but itll allow me to at least see in there.
I have a picture of the label on the back of the TV, if that helps also.
TV repair help?
Dude, be VERY careful if you're going to open that thing up. TVs can hold a charge even after they have been unplugged. At least, that's what I've read.
My friend had a TV that had a very strange problem. The picture would "creep" up the screen. If you slapped the side of it (very hard), it would shoot back down and be normal for a few hours. It always amused me that the stereotypical fix for a broken TV actually worked on this one.
TV repair help?
My 21" computer monitor has safety trip wires in it.  If you bang the shiznit out of the side of it you will see it go black for a second.  It resets itself.  I don't know but maybe tv's have a similar setup.
TV repair help?
You are correct Zach, the compasitors will hold a charge. This one has been unplugged for probably 4 months now, so it shouldnt be too bad.
Believe me, ive smacked the hell out of this TV
TV repair help?
I'd say the tube's dead, or something equally expensive...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
TV repair help?
Quote from: Red_LX
i agree shallow and pendantic
TV repair help?
I'd place my bet on the flyback transformer - it's sorta like an ignition coil (converts low voltage to very high voltage) and usually when a TV (or computer monitor) makes a sound it's a sign the flyback transformer is going bad
TV repair help?
buy my 36" sony vega flat crt set :) We really don't use it now where its at.
