Topic: Dash Cluster (Read 1465 times) previous topic - next topic
Dash Cluster
ok i have a dash light out right now and the dash is disassembled all the screws are out. there is a white wire holding it how do i get it out?
i have been working on this for a few days now does anyone know what i have to do to get that thing out? thanks
                                              -chris
Dash Cluster
That white wire is not a wire.  It is the cable to controll the shift indicator.  If you look under the colomn you will see that it is simply screwed on.  Be carefull they break easy.
Dash Cluster
ok yea i got the problem taken care of but now that i got the indicator back on that hook now the indicator is out of wack like when it says its in reverse its in overdrive
Dash Cluster
Loosen the screw a bit and rotate the clip around the steering column until the pointer is where it should be.
Dash Cluster
the clip is prolly broken. If it is, you need to hose clamp around it. Or the almighty duct tape.
Dash Cluster
Hose clamp works duct tape dosen't. Don't ask why I know.
Dash Cluster
duct tape always works, if you use enough in the right places.
