Topic: So much work...and no progress... (Read 3481 times) previous topic - next topic
Actually, you dont need special headers, you just need to run 90* spark plug boots to clear the headers. I plan on running some cut-to-fits since im doing things quite a bit different than most.
Low end grunt is nice, but im more of a corner carver, to where you need power to get off the corners, but you still need top end power, when im through the turns, the rev's are usually pretty high, and thats where id like the power to be. Im hoping the P heads and trick flow cam are a good match.
