Topic: Would my car have some sort of rev/speed limiter (Read 2787 times) previous topic - next topic
I blame this all on the fact that my speedo reads about 20 mph to fast.
Some times if I really give the cougar hell and take it to red line.  She will just fall flat, like the fuel got cut off.  But if I shift to the next gear and keep on hammerin it it will just keep going, like its not the speed.  But could it be the revs?  Its weird and I rarely take the cougar up to those high rpms but I was just wondering if maybe my car had some kinda limiter.
Valve float.
the only fox i rember having a limit at all was the mark's speed limiter. im going to have to go with shawn and say valve float also.
Your speed limiter is the 3.8
Quote from: stuntmannick
:mad:
Quote from: Shawn
Valve float.
I've never experianced valve float.  But I thought it didn't just happen, I thought it to be more like a missfire.
Does the 3.8L have the same 6,250rpm fuel cut-off as our 5.0's?  Although I really can't see trying to scream a 3.8L to any more than 5500...lol.
Quote from: Sick88Tbird
You don't know me very well..:evilgrin:
Quote from: CougarSE
You're absolutely right...lol....will that little motor chirp the tires going into second? :evilgrin:
:mad: Now that I have the 245/50's and a trac-loc it wont. With the old 235/55's It would. Man If I still had 14's on the car I could roast them through third.
But now I've got too much realestate to turn back there.
valve float will feel like the motor was just put on idle, most likely what it is if I was a guessing man, which i am.
Quote from: Funky Cricket
 thats what it feals like.  Hmm, need me some stiffer valve springs.......
At 6250 rpm, the 3.8 would throw pistons into orbit.  ;)
Quote from: JeremyB
I don't know how high I've actually had it, but I know its been into the red zone on that turbo coupe tach.  Wich is working well now for some reason.
is yours a 88? supercoupe stuff wount work would it? like heads, i know theirs also that v6 performance website that sells 6cyl stuff. maybe look their for some stiffer springs. it would be pretty sweet if you did the super coupe swap like spaz had done.
dont bother with valve springs. Replace them with a 5.0.
