Topic: Stock HO Camshaft (Read 4599 times) previous topic - next topic
Stock HO Camshaft
Is it possible to install the stock HO cam in a stock 87 T-bird without chaning over the computer and fuel injectors??? Thanks for the help...Love the site!!!
Re: Stock HO Camshaft
No. The HO cam uses a different firing order so the fuel injectors would be firing out of sequence. The SO computer would not know what to do with the different vacuum characteristics of the HO cam, and the injectors wouldn't deliver enough fuel to make it run decent.
It might run, but it wouldn't run good!
Quote from: Thunder Chicken
Well when you run the spark plugs wires differently, couldnt you also remove the injectors and place them in the right hole as well???I realize youd have to do some wiring extensions but it could be done??
That would solve the injectors firing out of sequence, but it still wouldn't change the fact that the SO computer would choke on a cam change. Remember, the SO computer is speed density, and speed density can't adjust for increases in airflow or vacuum. Like I said - it might run, but it wouldn't run well.
It'd be easier to swap the computer than it would be to rewire the injectors
With a STOCK HO cam the LSA is like 116 so the SD computer would be fine. The KEY to making any SD cam changes are to use cams that have a min of 114LSA. This eliminates any of the FORD "Alphabet" cams, I have changed H,C,I, on 3 different mustangs all while staying SD. My cam of choice is the Crower 15511.
Thanks for the information guys... It sounds like it would be easier to go with a Mustang computer... Do I need a special wiring harness or will it just plug into the existing harness or is there any special wiring that needs to be done.  Thanks again.
Just plug and play. :ies:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Thanks everybody!
Oh yeah, one more question, does it matter if I get a computer from a Mustang that had no power options if I currently have a car that does have power options.
Quote from: ablinkpunk
no.
when i install the cam will i need to install new lifters
With roller lifters in most cases you can just reuse them, they don't wear like flat tappet. :grinno:
just get an SD mustang computer and plug it in, you will be fine.  I just bought two off ebay, one for 19.95, and one for 25.00.  You need to get some 19lb injectors and an HO upper plenumn and TB to get the performance your looking for.  Also H.O. shorties can be had very cheap and are better than the stock manifolds although I would get some macs or other and do it once instead of upgrading later.  I had an 86 mustang gt rated at 200 horse and thats about what you will get with the HO cam, computer and headers.  I put the better upper intake, e7 heads and TB off an 87 on my 86 GT and it made a very noticible difference from 4200 rpm up.  It came on the pipe so to speak if you have ever rode a 2 stroke dirt bike you know what I mean.  There was no noticible difference in the low and mid though.  good luck
If your cougar is automatic trans, you will need a computer from a stang with auto trans too.  Not manuel.    Automatic computers works in manuel cars but NOT the other way around.
Quote from: merccougar50
Not so, the manual computer will work in a auto... That ONLY applies if you are using a AODE('94-'95 Mustang), that the EEC controlls the shifts.
