Topic: 5.0 SO upgrade using 351W heads (Read 1989 times) previous topic - next topic
So I've been talking to this guy at work, and he said a pair of '69 or '70 351W heads would give my motor some pep. Keeping in mind that this is the stock engine, I am wondering about the piston clearance - would there be a problem ?
Also, would these heads be a better choice over the E7TE from the HO ? I'm asking because there's a chance I might be able to get the 351W's for about a hundred or so dollars, whereas I haven't been able to find a good deal on the E7TE's yet.
Could I use the stock/HO intake manifold with the 351W ? (I know I have to use 351 gaskets and bolts)
Any other issues that you can think of ? Has anybody here done this ?
I have an '87 Thunderbird LX with the stock 5.0 SO.
2003 Triumph Speed Four
1992 Dnepr MT-11 30rwhp "Gracie"
Quote from: siscrew
Probably -
A 69-70 351W head has 1.84/ 1.54 valves and 60cc chambers.
A 87-93 E7TE head has 1.78/ 1.46 valves and 62-65cc chambers.
Looks like the intake ports are a bigger on the 351 head (1.94x1.76) than the E7 (1.94x1.04), but exhaust port size is the same (1.24x1.00)
So, by the books it looks like a win/win situation - bigger valves and more compression.  As long as you can figure out if piston-to-valve clearance will be a problem
You'd have to get a 351W manifold base but you could reuse your upper.
Quote from: 302Fairmont
NO NO NO!!! The engine determines the intake usage NOT the heads(at least in Windsor applications). Plus there are no stock 351 lowers that mate with any of the 5.0 uppers(other than Lightning/GT40/ Cobra/Explorer and they don't mate to any stock 5.0 upper or lower).
So, by the books it looks like a win/win situation - bigger valves and more compression.  As long as you can figure out if piston-to-valve clearance will be a problem.
Also the old 351 heads do not have hardened exaust valve seats for todays unleaded fuel(could have been added). If they are not installed the valves will burn in 8-10K mi. They are good heads otherwise, the iron GT40s are updated versions of the early 351 head.
Quote from: TurboCoupe50
Isn't there something you can add to the fuel to prevent this from happening? I know my father-in-law adds something to his fuel to allow him to run unleaded in his 1963 390.
yea hes adding a lead addictive since there was leaded gas back then, Id rather just spend the money on redoing the valves/seals and not have to buy cases of the stuff and just goto the gas pump and be done with it.
Since the heads are off, it would make more since to get them done so he can run unleaded fuel.
Thanks for the answers guys, I'm hoping the deal goes through ! Does anyone know about the piston clearance - would they work with the stock pistons ?
Um you have another issue.  351's use 1/2 head bolts.  302's use 7/16 head bolts.  You will have to buy a set of ARP head bolts designed for this swap to make up for the difference.
I've heard of spacers you put in the holes on the heads to make up the diff so you can use the 302 bolts.
Resident "Idiot".
Formerly TBob5pt0 :shoothead
Quote from: JeremyB;165772
Repairing a lock cylinder that is frozen or sans keys requires a drill, gumption, and a midget on a tricycle.
Quote from: Big_D
Forgot to put on intake hose when starting the car, sucked neighbors cat into intake.
Bad goof - I totally ****ed that up.  Seeing 351W so many times, I was in tall deck mode and thinking we were talking about a 351 block.
:flame: on me.
The heads wont give you much power, the biggest improvement would be the cam, and youd be better off going right up to a full HO swap.
