Topic: adapting mustang fuel lines? (Read 2218 times) previous topic - next topic
my 86 has the shiznitty neoprene fuel line. anyone ever try to adapt mustang hardline to a coug/bird?
86 thunderbird elan
86 mustang coupe
. The fuel lines...well then. The good news is, with an in-tank or in-line fuel pump, you're okay there. But getting the lines to the motor is another story. The metal lines going to the motor are okay, but they need to hook into the rubber lines before that. So this necessitates finding a way to adapt your stock lines. Ford does make a nice kit (p/n N803431-S) that makes life easy for you. It's two unions and 4 clamps, used to convert your existing lines over. Cost for the kit is around $10. If you find your car cannot use this kit, you may have no other choice but to run all new fuel lines from the tank to the engine.
Here you go straight from Eric's site so if it's not right its his fault :D
Hope this tells you what you need
SOLD!!!!
That method does work.
Mustang lines arnt all metal, they have a metal section that comes up past the exhaust manifold and up to the fuel rail. The problem is that the fuel rail may also be different, and may need to be had.
Lucky for you, 87-88 5.0 birds, cougars, lincolns, and other cars all have the same stuff.
Quote from: Tbird232ci
The '87 5.0 fuel lines are routed differently than the '88(but the line from the filter to the engine is the same). The '88 because of dual exaust, crosses over to the center of the chassis from the fuel filter, then back to the tank(basically same as LSC and Turbo Coupe). The '87 follows the passenger side frame rail then makes a right angle at the tank. Dunno about the V6 never looked at(or owned) one...
Quote from: TurboCoupe50
Wanna buy a V6 'Bird??? :evilgrin: :evilgrin:
lol, j/k I'd probably have to give ya some money to take mine! ;)
