Topic: looking to buy a cougar 3.8L need some info (Read 2894 times) previous topic - next topic
i have been looking at getting a older cougar about 87  and was wondering if i can fit sc pistons in my block if so how much booste will they handle and will the 87 computer handle twin turbo set up any info would be great the reason for this set up is to be differnet on the show curcuit
Re: looking to buy a cougar 3.8L need some info
I don't know if that will work but I really doesn't sound like it would. An 87 3.8 is really a horrible motor. Trust me i have one. They make very little power and there are no aftermarket parts for them. If you want to do a turbo setup an entire 3.8 sc motor would probably be a better place to start.
There's one guy who used to be on this board who goes by the name "Spazzpuppies" who had sucessfully installed a stock SC motor into an '87 Cougar.  He's the one who'll know about that swap.
what this guy is asking, is if SC pistons will go in the stock engine
honestly, its a bad idea, the 87 block is rather weak, the rods are very weak (look like something made by playskool), and the crank isnt very strong, the block is also a non-roller block, and the heads wouldnt allow much boost due to them not being revised like the SC's
if you want to go twin turbo, buy an SC engine, you wont need the intake manifold/blower assembly, use an intake manifold from an 88+ bird, or 94-98 mustang, and grab the fuel rail
for the wiring and computer, thats where it gets tricky, id recommend using the 94-95 mustang wiring harness, and computer, since its still OBD1, and it shouldnt control the tranmission if i remember correctly, youll also need the fuel injectors and all the sensors from the same mustang
its not an easy or cheap task, trust me, ive dont almost years of homework on this
you could use the mustang supercharger, but you still have to remember, the early engines are still more pr0ne to failure as opposed to the later model stangs
Mustang supercharger??????? :dunno:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
click here
http://p089.ezboard.com/bfoxthunderbirds
then go to "engine tech"
then go to page 19 (lower bottom of screen)
then click on topic """""3.8 stroker*****
I found it on page 19 of the old board and something occured to me,,,,,  nothing will ever fall off page 20 ever again :giggle:  cause there aint no one over there doing anything.
its on the old site.
Threads still get made over there, they just don't go anywhere because someone always catches them and directs the poster to the new site.
