Topic: WTB 83-86 T-bird in Ohio (Read 1204 times) previous topic - next topic
I'm in central ohio and i'm looking for a T-bird with good interior/exterior and prefered to run.  Don't matter what model just looking for something that looks good, aka good body, good interior! Motor work isn't a problem i'll make her run if she don't!  And i'm looking to pay under a 1000 bucks...
And if ya wanna just post t-birds you find in ohio that's fine.  I'm open to thinking about an 87-88 bird.  Since alot of us are from ohio, i hope this thread will be bumpin.  If not, i will just continue to drive my beater and put good parts on it, and not worry about it's looks until i can find that donor car someday.
:pics-stfu:
 Project Thread with pics
Check around your local hole in the wall lots, I picked up my 86 for $250.
Hey John!  So your starting a new project?  Up at the Don Wood dealer by walmart there is an 84 Cougar that needs some TLC.  Its white, sits in the back of the lot.  Also there is a hole in the wall dealer across the road from the movie theater in nelsonville, there is a red 88 cougar like mine there.  Don't think you dig the cougars though.  If I see any birds I will let you know, or call Kim so she can tell you.  I don't know how to get ahold of you anymore.?
Sorry I never responded to your p/m, I kinda forgot.
that's right claude! better say sorry!  Don't worry once it warms up a bit we're going fishing...  and i may check out that nelsontucky one but the DW car sux...
And the only reason i want this new project is because i'm sick of my car vibrating on the highway... so i'm looking for  something that's not boogered to hell.
edit:  and i'd prefer a t-bird cause for two years i've been wanting to get a t-bird logo  tattoo on my back and i can't cruise in the summer without my shirt in a cougar...
:pics-stfu:
That is too good john!
I have the one in my sig for sale.I can deliver aswell !
1985 Turbo coupe
Fresh motor (about 8,000 on it)
Ported factory head w/stainless steel valves
Esslinger roller cam and guides
Ported intakes
30# injectors
Aeromotive fuel regulator
255lph Walbro pump
Under drive pulleys
T/3 .60 trim
Gillis manual controller
Ported E-6 manifold
2 and 1/2in down pipe
Centerforce clutch
Re-surfaced flywheel
New slave cylinder
T-5 trans
Balance and new u-joint drive shaft
3.73 auburn gear
moser axles
disc brake conversion on the rear
Now for the body ..
The car has been re-painted due to sun fade.
The new paint is black and like glass ! GORGEOUS !
There is no RUST on this car !
The floor pans are solid , quarters are solid , MINT BODY !
Interior ...
Driver side door is missing arm rest but otherwise MINT for an 85 ! The seats are cougar seats and all the power still works !
This car is A-1 for it's age.Runs like a champ.Starts every time no problems.
I also have a parts car that u can strip and take whatever u want from for it.I also have an extra T-1 for it , head for it , intakes , injectors , distrubitor , and a intercooler.
I have not had a chance to go to the track w/it nor have i turned the boost up past 15psi yet.I've always ran 93 in it and w/15 and 93 i can say she rides for a 4 banger.I promise no dissappointments w/this car.I'm trying to get some pics up now.
WARNING:This car does not come w/the welds , it has 17' ROH's out back and pony up front , i do have matching ponys for it also , so u can pick !
3500.00 o.b.o
Yes... it is very nice but i'm a firm believer in the value of a T-bird... That one, i'd give 1900 for... but other than that i can't say it's in my price range.
:pics-stfu:
hi
I have a black with dark grey interior 1988 Thunderbird Turbo for sale.  It has $110,000 miles and is in good condition.  Has practically new tires.  It is loaded with moonroof, keyless entry, heated seats, automatic climate control and many other options.  I was the only driver and I treated it like a baby.  The back seat has only been sit in a couple of times.  It does  need some engine work, I am not sure what, I haven't had it checked out because I bought a new car.  I am located near Abingdon, VA which is in Southwest Virginia.  You can email me at sherry_c_1999@yahoo.com or call (276) 889-1917 or (276) 608-7519 if interested.  I will try to answer any questions you may have.  Depending on where you live on Ohio, it might not be to far from VA.  Asking $1,200 but price may be negotiable.  We can talk about it after you decide if your interested.  Looking forward to hearing from you.
Thanks
Sherry
