Topic: intake throttle body ? (Read 1332 times) previous topic - next topic
1st ? Which one yields more power a aftermarket cobra intake upper and lower or the typhoon performer plus. also would a 70mm tb cause any problems since im runnin a speed density set up.
88 sport 308 e-303, ported e7's, cobra intake, cold air, under drive pulleys, full exhaust, t5, 373's, smog pump removed, 255 pump, pressure regulator.
                        :birdsmily:
I think the 70mm is a little to much with stock HO+SD.But thats just my opinion,The intakes are both good but you would yield more with more cam with them than an ho of course mass air.
That Throttle body is a little much for stock HO cam and heads.  It'll work with speed density though.
Read these, there's some good info in em......
http://www.foxtbirdcougarforums.com/showthread.php?t=96&highlight=speed+density
http://www.foxtbirdcougarforums.com/showthread.php?t=1070&highlight=speed+density
http://www.foxtbirdcougarforums.com/showthread.php?t=2028&highlight=speed+density
Quote from: svtbird
the 70mm will be fine on either.I would use the cobra intake i wasnt real happy with the fit and finished of the last perf products intake.
From experience I know speed density is pretty intolerant to any modifications . It takes a alot of mods to really even need a 65mm TB. If you have the stock cam forget about it.;)
Only in America do we use the word "politics" to describe the process so well: "POLI" in latin meaning "many", "TICS" meaning "bloodsucking creatures".
im sorry i forgot to mention i am installing a e-303 cam,24 lb injectors, 1.6 rockers new lifters as well. also A shop offered to tune my computer maybe that will help?
                        :birdsmily:
you will need a computer that is set up for 24 lb injectors. You are talking mass air computer right there. It will run, but prolly like ass.
E-cam has 112* lobe separation.....might have idle/vacuum issues.  A lot of speed density guys go with the Crower 15511 cam.  Just something you may want to look into.
