Topic: Wheel and rack ? (Read 1223 times) previous topic - next topic
Wheel and rack ?
Will a 03 cobra wheel that is 10.5 wide fit on the rear of an 84 with a sn95 disc brake rear or do I need to stay with the fox rear and will a 9in wheel fit up front.
Are the rack&pinions the same width as a fox mustang and do they use the same tierod ends.
Are the upper & lower control arms on the 84 turbocoupe the same as mustangs and are the front suspension components all the same k-member,A-arms.struts,etc.
Wheel and rack ?
10.5" wheel will fit > s95 is the same width as the 86-88 t/c rear
the 9" wheel >will fit up front
Steering rack> I dont see why they wouldnt interchange.
control arms > some say 83-85.5 are the same as the mustang but i dont know
if you use a mustang k member you have to use the lower a-arms.
struts will interchange if you use stang spindles.
Wheel and rack ?
Thanks SLeeperT-Bird 87
