Topic: What brake parts do I need? (Read 1876 times) previous topic - next topic
I have an '88 sport.  I am going to be putting on brakes front and rear from a '96 Mustang.  Can I reuse my rubber lines in the front if I have the SN95 banjo bolt?  I am trying not to have to rig anything with that if I dont have to.  I am going to make some lines and brackets for the rear so that I can have the discs in the back.  Will I need to do anything with the prop valve, or the master cylinder?  Am I going to need an adjustable prop vavle rigged in there somewhere?
Matt :tg:
I'm not too sure about that front line thing, I suppose I can check when I get around to it (I'm in the middle of a 5-lug conversion), but I'm leaning towards a no. If it were possible, or a good idea, someone would of done it by now. Besides, modding the brake lines isn't that hard, plus they have adapters too.
Did you check out this site? http://mjbobbitt.home.comcast.net/mustang/mc.html
As for the last three questions... Yep.
I don't know about the caliper hoses or anything, but you will need a prop valve, i got mine fromg jegs for 40 bucks or so... and i know when i read on the coolcats site it says to change your mastercylinder to a turbocoupe one but i never did and i stop fine.  Probably won't have to change it out, but if you have issues go for it.
:pics-stfu:
 Project Thread with pics
I have SN95 hoses and banjo bolts, can I use those?
Matt :tg:
Quote from: slowfoxbird
yes but they require adapters or double flaring and what not.
Youll need an adapter to go from your current hard line, to the SN95 rubber line.
Quote from: Tbird232ci
ONly on one side.  SN-95's use different fittings on the front hardlines.
One side is 7/16-24INF and the other is 3/8-24INF...So one side will fit as is and one will need an adapter.
Cool, thanks for the help guys.
Matt :tg:
