Topic: Advancing a stock HO cam (Read 900 times) previous topic - next topic
Has anybody here done it with a stock HO cam?
Since I finally got my Gear drive set in the mail, I have been thinking of advancing the stock cam a couple of degrees, in my '88 stang for a little more bottom end torque (like it needs more:hick: )  and was curious if anybody else has done this before, and what were the results?
i would install it straight up or even retard it 2* .
Hi i have a good example after playing for a while on dyno with my cam just for fun. cam retard -2 on avg was 7hp less than +2 but to keep my cam degreed at card spec it needed to be -2. you really should degree a cam before playing with moving it around because valves and pistons dont agree with each other. good luck
