Topic: Timing question (Read 1328 times) previous topic - next topic
Timing question
Just contemplating moving my timing up to 12 or 14 degrees but Coolcats says that doing that requires 93 or higher octane fuel.  There's one chain around here that carries 92 but mostly it's all 91 so that's what I intend to stick with.  Is that too little to risk advancing the timing that high do you think?  I'm sure most of you have tried this so I'd appreciate whatever insight you have.
Timing question
advance it 2* at a time and listen for detonation..
i ran 12* on 87 octane
Timing question
same here...
~John~
Timing question
i ran 13 in my 86 5.0 and it did just fine.  i'd tease it and feed her some outlaw octane booster every fill up.
:pics-stfu:
 Project Thread with pics
Timing question
Anyone know the diameter for one of our 302 harmonic balancers?  I have a sheet of timing tape for different diameters but I can't really measure it with the pulley attached.  I may just compare all the diameter tapes to the timing marks and see which one lines up but it'd be nice to know in advance.
Timing question
Nevermind I found it.  For the record the typical balancer diameter for a 289-351 is 6.375"
