Topic: bird help (Read 6601 times) previous topic - next topic
bird help
hey. im working on my car still. its a standard 87 thunderbird. im doing the works to it that i can afford cause im still not even in college. but having some problems. the bolt pattern is a 4x108 and not to many rims fit it that are bigger than 17s. i want to convert it to a 4x100 which is the standard 4 bolt pattern on hondas n such, so granted any rim will fit. if you know how to do this and what ill need and where to get it, it would be most helpful.
check my site it needs to be updated, but its getting there. when i finish the car itll be hot as hell and it wont look like a tbird n e more so itll turn heads, but gotta represent n leave the good ol tbird symbol on it  :rice:
Re: bird help
Nooooooo! Don't do that to a perfectly good bird :screwy: Why in the world would you want to put import rims on it :brick: . Besides import rims would not work because the offset and backspacing on import rims is way different from the tbird wheels. :slap:
Re: bird help
the offset can be countered but i want to convert it to a 4x100 anyway
Re: bird help
yeah he's right dont do that to a bird! i hate imported garbage.
Re: bird help
yeah he's right dont do that to a bird! Imported garbage will look like shiznit.
Re: bird help
i really dont car , cause i never even said import rims, but i just cant find n e rims i want that fit the 4x108 bolt pattern import or not, if you know how to convert it just let me know thanx
Re: bird help
IMPORT RIMS LOL.. thats the last thing i would want to do!
Re: bird help
A guy with a 350 Chevy under the hood of his T-bird, mocking a guy who apparently wants to put ricer rims on his T-bird, for making a T-bird look awful.. am I on drugs and just don't know it?
I need more beer..
What the hell is going on around here? Is another regular testing everyone?
Re: bird help
convert to 5 lug and you will find lotsa rims available
Re: bird help
Yes do the 5 lug swap, anything but a honda  :toilet:  :crazy: bolt pattern. If you do the 5 lug swap you can use anything that fits on a mustang. All you need is the 5 lug rotors, calipers, spindles for the front and new rear axles out back along with the assorted brake hardware.
Re: bird help
Dont most ford cars use the same 5 bolt pattern? :brick:
Re: bird help
i doubt you can convert to a 4x100 pattern at all without makeing coustome axle shafts and front rotors, so if its rims your after, go with the 5lug conversion off a 94-98 mustang, or front rotors and brakes off a mark7 and rear brakes and axle shafts off a 94-98 mustang. theirs millions of wheels for that pattern anyaway and you get the proper spaceing. this will be far easier than makeing coustome rotors and axle shafts. and as for import rims,.. i'v seen civics running 10s with weld drag lights and slicks and if im not mistaking most mustang guys run them as well. wheels are wheels no matter what the bolt pattern...
Re: bird help
well i found wheel adapters that can change my bolt patern to the 4x100 any way for 130 so i think im just going to do that
Re: bird help
You should be able to find thousands of wheels that fit. They make alot of different wheels for the 79-93 Mustang, which is the same pattern as the Tbird/Cougars. :ies:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Re: bird help
Instead of looking for 4 x 108 try looking for 4 x 4.25.
Yes they are the same but one is metric and one is standard.
You will find alot more rims if you look for the 4 x 4.25.
