Topic: Thunderbird ejection seat (Read 3460 times) previous topic - next topic
(stolen from another board)
Thunderbirds accident report released
Air Combat Command Public Affairs
LANGLEY AIR FORCE BASE, Va. (ACCNS) -- Pilot error caused a U.S. Air Force Thunderbirds F-16 aircraft to crash shortly after takeoff at an airshow Sept. 14 at Mountain Home Air Force Base, Idaho. The pilot ejected just before the aircraft impacted the ground.
According to the accident investigation board report released today, the pilot misinterpreted the altitude required to complete the "Split S" maneuver. He made his calculation based on an incorrect mean-sea-level altitude of the airfield.
The pilot incorrectly climbed to 1,670 feet above ground level instead of 2,500 feet before initiating the pull down to the Split S maneuver.
When he realized something was wrong, the pilot put maximum back stick pressure and rolled slightly left to ensure the aircraft would impact away from the crowd should he have to eject. He ejected when the aircraft was 140 feet above ground - just eight-tenths of a second prior to impact. He sustained only minor injuries from the ejection. There was no other damage to military or civilian property.
The aircraft, valued at about $20.4 million, was destroyed.
Also, the board determined other factors substantially contributed to creating the opportunity for the error including the requirement for demonstration pilots to convert mean sea level and above ground level altitudes and performing a maneuver with a limited margin of error.
Re: Thunderbird ejection seat
That woulda been cool to see  :eek:  (nobody was hurt I can say that!)
