Topic: quick sway bar question (Read 1232 times) previous topic - next topic
does a 5.0 and a 3.8 car use a different sway bar in the front? when I dropped the 5.0 in my car the first time it would go all the way in because of the oil pan resting on the sway bar. we ended up having to put blocks under it to hold it up off the bar. only bad part about that was the air cleaner rubbed the hood insulation bad enough it left an imprint in it. and the sway bar was still only an inch or so below the front sump of the oil pan.
SOLD!!!!
