Topic: cam ? (Read 1006 times) previous topic - next topic
cam ?
Hey guys, got a question. first off this is what i have, stock SD with HO upper,throttle body, true duels, no cats, crossover,flows,shift kit, 3.45 gear. question is will the crower 15511 cam work for me and what else do i need to be able to install it?,,,,, SD HO computer? 19# inj? fpr?  is this a good light performance cam for a daily driver that just wants a little more uumph??
 thanks, Joe
cam ?
Yes.
Yes.
The specs are 218* duration intake 224* duration exhaust .468 lift intake  486 lift exhaust with 114*lca with 1.6 ratio rockers....  This SHOULD be good as far as piston to valve clearance.  Check it to be sure.
cam ?
Quote from: Paul Flockhart
Yes.
Yes.
I second this.....
cam ?
thanks guys, i am going to order it tonight!!! my dad lives about 5 min. from summit and he will be coming down in a month, by then i should have everything i need (plus the weather should break a little). anyone have a SD HO puter they would like to sell me???
Thanks again, Joe
