Topic: Catalytic Converter Question (Read 1491 times) previous topic - next topic
Okay, so I'm pretty sure it/they are plugged up. I have an '85 T-Bird with the 302. So, does the car really need them? I don't have to smog the vehicle in my county. I know, probobly a stupid question. But better to ask once then fix twice.
1985 T'Bird 5.0
1987 Cougar 3.8
1992 T'bird Sport 5.0 HO
Since you live where theres no emissions,  I would just take them off, gut them and reinstall them and be done with it.
20006 Ford Fusion SE
Your car should run perfectly fine without one. They aren't necessary and I don't have any on my car right now like many other people here.
Cool, I was worried since a friend said it needed them for a sensor er' something.
1985 T'Bird 5.0
1987 Cougar 3.8
O2 sensor will prolly set codes, but they are not needed, And i think you can find an 02 delete.  Someone verify this for me, My computer is in the ocean :) , so i cant be sure this is accurate, just what I've read.
his o2 sensor should be above the cats in the manifold so im not sure if it will effect them at all, but he will get better mpg expecialy sence their plugged up.
O2s are only effected on OBDII cars with sensors after the cats to monitor there performance.  You will be fine.
Sweeeeeet! Thanks guys!
1985 T'Bird 5.0
1987 Cougar 3.8
