Topic: Slowly getting parts :D (Read 2246 times) previous topic - next topic
I know ya dont care since its for my mustang :p but I figured I would share anyway. Have to do a compression test today, #4 is making a weird noise from under the valve cover and seems a lil underpowered...hopefully everything works out.
So far i have the following layin in my room:
Lakewood 50/50 rear shocks
Lakewood traction bars
FMS B Springs
next will be some lakewood 70/30 front struts and possibly lakewood control arms, see a pattern?:giggle:
A fox is a Fox..............Hope the noise isnt anything serious.  Let us know what you find.
comp. test came back as follows:
cyl 1: 130
cyl 2: 132
cyl 3: 132
cyl 4: 142
cyl 5: 150
cyl 6: 135
cyl 7: 139
cyl 8: 127
not to bad, but I realized the spout was still unplugged from checking the timing on friday, plugged it back in..whole new car lol.
Congrats glad to hear it.  Now get those parts installed
yeah it all looks good till you get to cyl 8. not too sure on stock compression but that looks way off the others. not too sure if there could be an issue with that cyl or not. but did ya doble check that one to see if the pressure changed on 8?
Got that fox rash again!
-Resident smartass! :ies:
i took to tests on each, then averaged them. it was 130 then 125. It didnt plug the spout in until I was done could that have anything to do with it?
I cant yet lol, just ordered lakewood lower control arms :) still need uppers and front struts then everything can go on yay
Sweet deal. I really like the way your stang looks. Not ricy at all. Looks well done and well put together. Congrads on keeping a great looking car.
thanks your cougar looks mighty nice to :) what color blue is that?
id like to get some 15x5 welds for driving around on the street, just dont trust those 3.5s to much lol.
Did you remove all of the Plugs from the car when you ran the test?  You should remove them all at once and tie open the throttle plate.  Oh and unplugg the fuel pump relay or pull its fuse so its not trying to kick on when you bump the car over.
My cougar's 3.8 was 160 Psi  Across the board.  I was surprised.
Quote from: Bane
You are correct :evilgrin::rollin:
cougarse: only removed the side I was on at the time.
chuck.. :cry:
Quote from: Bane
02 Chevrolet Corvette Electron Blue Metallic w/ a hint of purple pearl.
ah nice, thats a very good looking color. My other mustang I had before I parted it out about this 90 was gonna be painted the mid 90's dodge blue. Intense Blue Pearl, found on the trucks and neons I think.
