Topic: Speedo driven gear (Read 1326 times) previous topic - next topic
Speedo driven gear
Hey I was wondering if this gear would work in my AOD:
http://www.mustangsunlimited.com/itemdy01.asp?T1=DFM17271J+01&Category=Drivetrain&subCategory=Speedometer+Gears&CatKey=74-01
I've got a 8 tooth drive gear in the tranny and 3.73 gears out back. I've got a 21 tooth purple driven gear in right now and the speedo seems to be about 5-7 mph off. So do you guys think that this 23 tooth auto transmission driven gear would make it closer? Also can I get it from a Ford dealer?
Speedo driven gear
Thanks :D . It says I need a 24 tooth gear so since the 23 tooth gear is pretty close that should help correct it alot. Now I just have to see if my local Ford dealer has one and if not I'll just order it.
