Topic: Got a few questions and observations... (Read 1412 times) previous topic - next topic
Well I just bought my first fox body, an 88 bird with the 5.0 and AOD. 1. Will a mustang off road "H" pipe fit the stock cast iron manifolds?
        2. If it won`t, I`m thinking that I`d hafta install a floor shifter to help with any clearance issues with the column shifter.(headers)
        3. Will the mustang aluminun driveshaft bolt into my bird?
      Thanks. Things are so much simpler on a old galaxie...
Mustang driveshafts are too short.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Big thanks!
Quote from: Red_LX
 Thanks, that`s what I figured.....poo.
So how old of a block (302) will work in a fox with the stock FI? I was thinking about building an engine and wondered which years to look for. Thanks.
Well if you have mass air I think that any 302 block would work even non rollers. The cams have to be within a certain spec though or you could have problems with idle.
