Topic: 92 Cougar Keyless Entry Pad (Read 2450 times) previous topic - next topic
Does the door panel need to be removed to remove the keyless entry pad on a 1992 Mercury Cougar XR-7?  The backlighting on the keypad is dim and I was looking to repair or replace it.  Thank you!
Re: 92 Cougar Keyless Entry Pad
I'm thinking yes.
Yea you'll have to remove the door panel for acess to the plug to remove it from the door. Then you'll need another one, as it is a sealed unit and the lights are not replaceable.
