Topic: N2O question (Read 1222 times) previous topic - next topic
N2O question
i got a question for any nitrous guy out there i need a guesstament on how much nitrous my car can handle my set up is a 306 with
281kb pistons about 9:1 compression, arp head studs, arp wav lock rod bolts, arp main studs,and fel pro perma tourqe head gaskets thanks if you need any more informatin let me know thanks every one
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
N2O question
With the KB pistons I wouldn't spray much more than 125 shot
N2O question
125 that sounds repectable thanks for the info man so the kb cant take too much jucie then do they break or melt
N2O question
cast> 25-125h/p is considered safe ive ran 175 on a good tune for over 2 yrs on a set of cast pistons They broke on 250h/p
hypereutectic> 75-150h/p is considered safe
forged>Ive seen up to 300h/p worth of n2o on stock h.o pistons with a good tune.Good aftermarket pistons and a safe tune and supporting fuel system will make or break it.
Your fuel system will make or break it as will the tune.
N2O question
Very true about the fuel sytem and check the A/F ratio. THe sytems are normal safe but I've seen them be lean.
N2O question
Agreed.  Get yourself an AFPR and a good guage as well.
N2O question
I would try to find a dyno or read the plugs after the 1st easy pull
N2O question
sounds good so i 125 shot would prolly be the best maby 150 if all checks out good and an air fuel ratio guage would be a good asset any thing else that might make this a lil more safer and reliable
