Topic: Amp Rack (Read 4461 times) previous topic - next topic
Amp Rack
Amp rack so to speak.  Alpine MRD-M1000 with a cap on the right.  Most of the wires are ran out from behind the amp rack.
Sub box: 2.5 cu ft sealed seperate chambers for 2 old Alpine Type R 12's.
This is an alpine RUX-4280 which allows me to control all of the amp setting from the front seat of my car.  It used to have a green display, but some 0603 LED's and a couple hours I changed it over to blue.  Amp level is set to about 900 wrms at 50Hz test tone.
I don't run any rear speakers, so I miss out on midbass and what not.  Only using 3.5's in the dash off the deck.  It does sound good none the less.  =)
Here is an example of what the amp will look like soon.  This is a smaller amp that will be used for some comps in my other car.  Which I powder coated white.
Jason
