Topic: Amp Rack (Read 4062 times) previous topic - next topic
Amp Rack
Who here has an amp rack in there car.  I am wanting to relocate my battery to the trunk and build a nice combo battery amp rack.  I'm not wanting to enclose the battery because I have an optima.  I don't usually do audio stuff but I shampoo'd the trunk carpet in the cougar today and I decided that the amp need not roll around on the floor anymore.  What has everyone here done?  Its only a Kenwood 600 watt.  More than enough for me.
Amp Rack
I attached some velcro to the bottom of my amps and have them stuck to the shelf in the trunk towards the front of the car.  They don't slide around at all and are pretty stable.  Do you have a sub box in there?
1987 Thunderbird 3.8. Sold :(
Amp Rack
i screwed mine (the amp i mean) too the underside of the deck upsidedown between the 6x9 with rubber sleeves on the bolts.
~John~
Amp Rack
I will be building a custom enclosure to go under the package tray.  I wan't my two tens but I dont want the big bandpass box i have now.
I'm thinking I'm going to build a battery box on the right side of the trunk and mount the amp to that.
Amp Rack
I mounted my two amps to the factory amp rack:
Amp Rack
Quote from: CougarSE
Are you only looking for combo battery amp rack ideas?
Amp Rack
what kinda amps are they carm?  i was told that amps can only be mounted level to the ground except cirtain types, but im not big on audio stuff so im not sure if its bs or not. eventualy id like a setup like that, expecialy sence i dont have all the moduals that a tc has back their so i got some room.
Amp Rack
One's an Alpine 4-channel, the other is a Precision Power. I've never heard of any problems mounting amps vertically - given that they're solid state with no moving parts or acid to spill I can't see what difference it would make...
Amp Rack
Quote from: Thunder Chicken
If mounted vertically, you should mount it in such a way that the cooling fins run vertical as well.  I attached this pic but Thunder Chicken's photo shows it too.
Amp Rack
Yeah Karl, I'm wanting the amp to actually be on display, its purdy.
Amp Rack
eh....why?
~John~
Amp Rack
Heat rises, If the fins are vertical it allows the heat to escape from the heatsink.  If they are horizontal it creates little pockets of heated air that will not move away from the amp, causing it to overheat.  If its flat it doesn't matter.
Amp Rack
I was tired of having my amp attached to my box.  So I took a piece of MDF and mounted it at such an angle that it fit between the top of the rear deck and went down.  I will take a couple pics to show what I mean.  It cleans everything up quite nicely.  Allowing the wires to be hidden behind the board.  I need to upgrade to a bigger alt soon though and or even a new battery as well.  Sometimes with high current draw from my amp the voltage goes from 13.8 to about 11.7. :S
Jason
Amp Rack
hmmm, nice theory, never thought of that. makes sense. must be realy porking mine as they are mounted upside down. i think its probably a non issue with a quality amp. dead airspace is dead airspace. other than a sub moving air around in a sealed trunk.
~John~
Amp Rack
Quote from: Blazin_Jason
Jason
That is uber ridiculous.
