Topic: Trunk dimensions? (Read 3923 times) previous topic - next topic
Trunk dimensions?
 I'll bet that hit like a mofookie. My 600w amp draws just enough when peaking to dim the lights a little. It doesnt start to effect idle until you stop at lights or in traffic, just turn it down a bit. Get a capacitor and that will keep that problem away. I plan on running 1600w in the Escape. So hopefully itll handle that with a capacitor.
Trunk dimensions?
My sprint with the stock 35 amp alt will keep up to my JVC 80/200W headunit powering two 4's and two 6X9's aswell as a 10" and 150/360 watt Amp. The voltage guage drops a couple volts when the bass is pounding but it stays between 14 & 16. The alternator is brand new.
Funny thing is the Volt gauge and the tach sway back and forth together :p
This is also with a battery slightly larger than a pack of cigarettes
Trunk dimensions?
I know my trunk is big enough for me crawl inside it and lay down, because that's what I did when I put my new 6x8's in my rear deck :) And that's no small feat considering I'm 6'4"!
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Trunk dimensions?
Im 6'4'' and i was laying on a sub box hookin up 6x9s and some friends tried to shut me in, only my foot was stoppin them. Stuff some bodies in this thing, or not.
