Topic: TC front sway bars: Same bushings/links as Mustang GT? (Read 3256 times) previous topic - next topic
-now i am not aware of how or what the aftermarket is offering, but according to the computerized parts catalog for ford says 84/91 mustangs all take the same sway bar link kit, which is e6zz-5a486-a,  87/88 tbirds with sport handling takes the same kit.  87/88 birds w/o sport handling takes e6ly-5a486-a, which shows to have the same contents as the e6zz kit, except for the insulators, which have a different part number. the 91/93 mustangs has a different kit altogether for those two years only, f1zz-5a486-a, which kit contents is entirely different and is 5.0 only, 2.3s are different insulators......hope this can either clarify or muddy up the water more......
OK, 'nuther question before I buy all those parts: What's the diameter of a stock '87 TC sway bar?
-according to the Bible, i mean ford catalog, All TCs had 1" from 83-88.  3.8 had 1-1/16 std, or 1-1/8 for h/d.  all 5.0 used 1-1/8.  then there also a couple listed as 1.  a car with sport suspension handling as 1.3" and 2. all except h/d a 15/16 bar.  no engine size or other requirements given.  12 years at this and is still confuses me, however, on some bars if you could find it if its still present there are identification markings given in code or paint color to determine what was on the vehicle, as i said though, IF you could see or find it....such as 2g, 2w, 1v-g, etc, etc.....:screwy:
The front bars are typically 1-5/16 to my knowledge.  The best thing to do is measure with dial calipers for the best accuracy.
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
Quote from: shorangerbird
Well my 84 XR-7 had the big bar (33mm/1-5/16") front bar...and any of the others I seen have definitely not had a 1" front bar.
Quote from: Chuck W
-as i said, 12 yrs and evrybody still has somthin different.  i'm just quoting from the info provided in front of me by fo mo co.....:dunce:
