Topic: Tps ? (Read 1046 times) previous topic - next topic
Tps ?
Good morning guys, just picked me up a HO upper, throttle body, egr for $20, in very good cond.  will my tps from my SD work on the HO? is there any diff between the two,  Thanks
Tps ?
You can use the same TPS.
