Topic: trans swap (Read 1337 times) previous topic - next topic
trans swap
how hard is it to put a t-5 in an 84 t-bird
trans swap
should be a breeze. same as any other fox. its a pretty streight foward swap.
~John~
trans swap
I just installed one in my '88 Bird.  Was easy.  But I guess that would also depend on your Mechanical skills too.  If you are just getting into working on your car, on a scale of 1-10, I would give it about a 7 for difficulty for a newbie.  If you have been doing your own work for awhile and are confident with your skills, I would say it is about a 2 then.  The worst part is getting the pedals in.  Takes forever to get that one  nut tightened!
trans swap
Quote from: 1WLD BRD
im a mecanic by trade but this is my introduction to thunderbirds.
trans swap
Good.  Then it should be a walk it the park.:)  Think of it as doing a clutch job on a '87-'93 Mustang.
trans swap
Just did it to my cougar, easy
trans swap
next question is about cost. how much will it caust to get the trans, pedal, flywheel, bellhousing, and any other parts i might need? i know that no matter how well planned i am at the start i will end up not having everything but i would like to know about how much it should caust.
trans swap
depends on you and where your getting your stuff vs what you actually get. my donor was a 89ish mustang. i got the whole car for 100bucksas a trade at my uncles dealership. all i bought new was a frpp clutch cable and quadrant, frpp king cobra clutch and pp, and a rear main seal. pretty much the rest came out of the stang. i forget what i paid for the new parts but less than 250-300.
~John~
