Topic: how much does your ride weigh (Read 3376 times) previous topic - next topic
hey every one i was just wondering how much your cars weighed what you have in them or what you took out of them to get that weight and if any one knows what the weight on the car is suposed to be all right thanks every one.
:flip:I GOT MORE POWER NOW:flip:
:mad:..BUT I NEED EVEN MORE..:mad:
3640 lbs w/o driver and 1/4 tank of gas.
I haven't made any attempts to lighten the car and it doesn't have any extra weight in it either (like a spkr box)
Dunno but i would guess mine to be around 3,500 lbs with the 429 and auto.. car is mostly gutted.. single aluminum seat etc,..
I will weigh it next trip to the track this spring.
My '83 was 3250# w/o driver (and about 1/4 tank of gas) last year before I got into it for paint.
At the time it was as such:
-2.3T/T5
-cage
-2 power front seats
-full interior
-SFC's and STB
It should probably still be about the same with the following changes:
- additional cage bars
- removed rear seat
- remove power front seat tracks.
Weighed mine on a truck scale once. With a trunk full of , 1/2 tank of gas and me @ 280 lbs mine came in at 3800 lbs. So it's probably between 3400 and 3500 empty.
so these  car are preety  heavy that sucks i had all my calculations figured out to get my car into the high 12's or low 13's with the weight but i kinda figured the cars weighed about 3500 do you think i went a lil to low when i did the power to weight ratio my car has no reductions maby some more weight it has a sn95 7.5 rear and spindles and 302 with c4 and 2 10's in a box prolly weighs like 100 or so pounds
meh....shopuld be close enough....i usually figure on 3600lbs - 3800 lbs for calculating estimated 1/4 hp etc.....
~John~
~John~
~John~
tripple post...ducking computer....lol
~John~
weighed my auto 88 TC with half tank of gas, without me in it. weighed 3360lbs. sounded a little light but who knows?
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
last time i weighed in it was 3460 but that was a couple years ago.
WOW!! You guys have some pretty light cars there, according to my door sticker, mine weighs in at 4,132 #s, so I'm assuming that means no gas or driver.  Why is it that mine weighs that much, or is it an error on the sticker?
'86 cougar gone to the big yard.
'86&'88 Jeep Comanches.
Quote from: Sprayingsmooth
Your car probably isn't any heavier than mine....The 83-86's were lighter than the 87-88's
Quote from: venom_cat_86
That isn the Gross Vehicle weight...as in the MAX the car should weigh fully loaded.  That is not the curb weight of the car.
