Topic: fiberglass intake. (Read 1386 times) previous topic - next topic
fiberglass intake.
Hey I was curious how a fiberglass intake would work? I am kinda sorta passivly thinking about a dual center throttle bodies, that could easily use ram air for the turbo coupe hood. Mostly just a I am bored at work daydream type thing. Would a fiberglass upper intake be feasable? just basically blant curiousity.
fiberglass intake.
You'd be better off going with a dual 4-bbl intake and adapting EFI and the throttle bodies onto it (presuming, of course, that your engine was making a gazillion horsepower and actually needed all that air).
A fiberglass intake would work (many OEM intakes are plastic) but you'd never be able to make one at home with the precision that would be required...
fiberglass intake.
Hey, he could start making "picasso" intakes...lol...
fiberglass intake.
yeah that is what I figured. Like I said, just curious.
fiberglass intake.
One thing you could do that wouldn't require so much precision is make a fiberglass intake tube that would match up to the TC "ram air" scoops. Or you could make one that pics up air under the rad...
fiberglass intake.
Have you ever looked through the T/C scoops on a car with a 5.0?  All you see is distributor cap and wires...that wouldn't be very feasible.
