Topic: CAT/BIRD RollerRockers 3.8 From WindAerostar? (Read 1437 times) previous topic - next topic
Is there a swap for my 87-TBird 3.8 where I can get roller Cam and Lifters and/or roller rockers?  In my surfing I vaguely recall someone saying something about how the Windstar or Aerostar 5.0 rockers could bolt on where the conventional (non-shaft) 3.8 rockers are?  The idea I seemed to glean was that the RollerRockers did not need a round shaft upon which to rock but rather bolted on to the same pedastal as do the conventional 3.8's.
If I remember correctly all the 3.8 heads are pedestal mount so Mustang ones will work however if I remember correctly again, the 3.8 motors came with 1.7 stamped steel rockers and all the Windsor motors came with 1.6. Please someone verify this for me cause I'am not 100% sure. If you want roller rockers you can use ones for a Mustang as long as they are pedestal mount.
James
You are correct.  Morana racing makes 1.8 ratio roller rockers for the 3.8.
so would the 1.7's work on the 5.0
Quote from: CougarCoupe88
Yeah it is called a poor mans rocker. So go to the yard and pull them off and put them on your 5.0. You know have gone from 1.6 to 1.7 ratio for probably under $30. Cheap little trick. I wouldn't run 1.8 3.8 rockers on a 5.0 though that would have terrible valve train geomotry I think.
James
Just an FYI of sorts...Aerostars never came with the 3.8 to my knowledge. You could only get them with a 3.0, maybe the 4.0, and a scant few had 2.3's in them (they had the same engine options as the ranger)
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
i know what im looking for next time i go to the junk yard. Sweet
Quote from: srv1
James
Man, when I asked that question I got the the thumbs down. Have you done this yourself?
well im gonna try it so i'll let you know
Quote from: Red_LX
Your right with that, the windstar had the 3.8.  Had split port heads to if that makes differnce.
