Topic: Springs,... Who Has What with Pix (Read 40940 times) previous topic - next topic
Springs... Who Has What with Pix
Reply #60
Yeah suspension techniques doesn't make those springs anymore.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Reply #62
Stock '84 Tbird
'94-95 SN95 spindles/brakes up front
out-of-the-box '99+ Mustang GT convertible springs from Eibach
1984 Thunderbird V8
Reply #63
Sits and fills nice how's it ride,It is pretty ,For a bird.
Reply #64
Wheres the moulding on the right side?
Reply #65
It's all in the dumpster right now.  I was checking to see if I could restore the mouldings or if I should just knock all the adhesive off when those pics were taken.
So the adhesive is gone now.  I wish someone would repop that .  I haven't seen a Fox Bird/Cougar with good mouldings in probably a decade.
lol @ looks good for a Bird.  I always thought the Cougars looked funky, with a roofstyle completely out of order with the otherwise swoopy lines of the car, but to each their own.  ;)
1984 Thunderbird V8
Reply #66
You mean the chopped window? Where the air keeps the trunk down and the rear?.
Reply #67
thunder306, how much for the h&r springs??
Reply #69
Quote from: kitzdnm;131186
lol, don't even mention aerodynamics...
Please note that there were no Cougar Pro Stock or NASCARs..
But seriously, everyone has their own preference.  Just thought it was funny to see "for a Tbird" in your reply.
1984 Thunderbird V8
Reply #70
It was more of a joke.I have owned 3 birds before my cat.
Reply #71
WHAT springs,Who has the answer?
Reply #72
I'm gunna play on good friday,Maybe I will have some insight.
Update!!
Reply #73
Well bubbas,My cars home.It's different.I used lowering springs, It raised the front ,Tighter steer tho.I am goin to run it a little to see if it settles.Then get it aligned.Took the shake out of mine.
Not sure what was wrong.But everthing was changed,What a difference with 15-1.And 11" brakes.I tried to take measurements before I ripped it apart and realized it was f'd .
So I eyed it to make it home,I'm close,But not right.
Update you all later.
Reply #74
I have the long gone discontinued Eibach lowering springs that were made for our cars..... I bought the whole set for $50 bucks on ebay from someone who probably didn't know what he had....
They dropped my car around 1"  in the front and 1 1/2" in the rear........
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
