Topic: These are for the Carbed motor right? (Read 1142 times) previous topic - next topic
I bought them off E-bay for the '85 Cougar, but I was thinking about throwing them on the t-bird if they would clear the upper intake.  I haerd somewhere that you can use them if you have a phenolic spacer.
they look like efi covers to me.
Nope they're for carb'd engines. You could probibly use them with a spacer but you would have to figure out a how to route the pcv air intake line or use a breather on the passenger side cover. I don't know if the breather would hit the throttle cable bracket though. Other side should be fine but your oil fill hole is going to be under the upper intake :D .
I had a set they are carbed and will not work with aftermarket roller rockers................Learned the hard way
