Topic: Steering wheel puller thread specs (Read 3168 times) previous topic - next topic
Does anyone know the steering wheel puller thread specs for the two bolts that go in the pulling holes?
BTW, I'm using the one-size-fits-all harmonic balancer kit from Advance Auto.  All I need is the right bolts.
I only found this thread:
http://foxtbirdcougarforums.com/showthread.php?t=424
loosen the nut off till its level with the end of the threads, rest a ball peen hammer on it, push on the back of the wheel with your knees and hit the back of the ball peen hammer with another hammer. Nice and simple and doesnt cost a thing.
Quote from: tbirdscott
Are you talking about that center bolt?
Also, I don't know if this approach would work for me when the steering column in out of the car and on the floor.
Should still work, hold it by the steering wheel and let the weight of the coloumn pull down on it, couple whacks with a hammer should pop it off, maybe get someone else to hold the steering wheel while you weild the hammers.
Ok, I'll try but I'm not understanding this part :confused:
If that doesn't work, I'm going to get a lot of looks walking into Lowe's with a steering column. :wtf: :screwy:
Quote from: Cougars 2 go
You know how the threaded part sticks out farther than the nut when its tightened? you want to loosen the nut till it is at the end of the threads and they are level so that when itshiznit with the hammer it wont damage the threads. Its not really necessary since it wont be hit that hard but its a simple and free percaution, I've ruined enough bolts that I usually do this to everything.
Oh, mine isn't a nut, it's a bolt.
I just changed out the sterring colum. 84 colum in a 86 cougar. It is fun, and the colors are the same.
Actually talking about the nut that holds the wheel on the steering shaft. You're knocking the shaft out of the wheel, rather than pulling the wheel off the shaft. Leave the nut on to (depending on where you're working on it): protect the threads, keep the wheel from smacking you in the face, keep the column from dropping on your foot.
Hmm Eric I think 1/4-20 would be too easy.  I know my autozone puller doesn't have the right bolts.  There is a pair that almost fits, good enough to get the wheel off but they dont' go in but a turn and a half.
I have a steering wheel puller that my dad created a loooooooong time ago at the tool and die shop. He had a bunch of odd size bolts in there, but the ones that work for every single Cougar steering wheel I've ever pulled (and there have been quite a few) is the 1/4" one. It is definitely standard, not metric, and I believe it has a normal thread. That's the best I can say.
Quote from: EricCoolCats
Quote from: MasterBlaster
Hey thanks for your help everyone.  I ended up driving my white 87 to Home Depot and walking in and out with a measure tool and some bolts.  It came out to be the 5/16" - 28 fine thread.  I bought the only type they had, strength grade #2 at 3.5" long.
I came home and they fit great in the '86 and '87 and '88.  I would advise no less than 3.5" long though.  I would also advise a higher grade.  The only reason I didn't get a higher grade was because that is all they had.  They did the job though but the lack of strength allowed them to bend a little.
